(R/C107): diagrama de fusíveis USPEC - 450SL (1976)
"On the top is a key with a triangle 5 amp (yellow); rectangle 8 amp (white); employ circle 16 amp (red) and filed circle 25 amp (blue). only the radio in position 14 is a yellow 5 amp. All others are either 8 (white) or 16 (red). I've indicated the colors below:
1 - clock, trunk light, standing light right and left, glove compartment light, warning buzzer, hazard warning light, entrance/roof light, electrically operated antenna (white - 8amp)
2 - Auxiliary fan (Red 16 amp)
3 - Power window motor front right + rear left (red 16 amp)
4 - power window motor front left + rear right. (red 16 amp)
5 - horn (unreadable) (sliding roof) (red - 16 amp)
6 - blower motor (red 16 amp)
7 - heated rear window (seat heater UNREADABLE, right and rear) (red - 16 amp)
8 - emission control, seat belt warning system, back up lights, automatic transmission. (white 8 amp)
9 - air conditioning compressor with over drive UNREADABLE (white 8 amp)
10 - stop lamp, turn signals instrument cluster, tachometer, cruise control (red 16 amp)
11 - Windshield wiper, windshield washer pump optical horn (red 16 amp)
12 - cigar lighter, (seat heating front left) (white 8 amp)
13 - tail/parking/starUNREADABLE/ right, side marker UNREADABLE lighting for license plate, thermometer switch, dash board, shift indicator, hazard warning flasher (white 8 amp)
14 - radio (yellow 5 amp)
15 -LEFT BLANK
16 - standing light left, parking light left, tail light left (white 8 amp)
17 - high beam right, high beam indicator (white 8 amp)
18 - high beam left (white 8 amp)
19 - low beam right, fog light (red 16 amp)
20 - low beam left (white 8 amp)"
» (R/C107): diagrama de fusíveis USPEC - 450SL/SLC (1978)
» (R/C107): diagrama de fusíveis USPEC - 450SL (1973)
» (R/C107): diagrama de fusíveis USPEC - 560SL (1988)
» (R/C107): Diagrama elétrico 450SL
» (W168): Diagrama de fusíveis - identificação dos fusíveis
