(SONORIZAÇÃO): Diagrama do Sistema BOSE de Som (W140)
(SONORIZAÇÃO): Diagrama do Sistema BOSE de Som (W140) Empty (SONORIZAÇÃO): Diagrama do Sistema BOSE de Som (W140)
Mensagem por Karl Fass Qua 26 Set 2012, 21:31
Segue para consultas.
Item Designation Coordinate
A2 Radio 4A
12A
19A
A2/15 FM bumper antenna amplifier 17L
A2/16 AM rear window antenna amplifier 19L
A35 CTEL transmitter-receiver 5L
F3 Fuse box (35-fuse, in fuse and relay box F1) 10L
F3f22 Fuse 22 10K
F4 Fuse box in trunk 1L
24L
F4f16 Fuse 16 1K
24K
H4/1 Left front door speaker group 28L
H4/1h1 Speaker 1 28L
H4/1h2 Speaker 2 29L
H4/1x1 Left front door speaker group connector 27J
H4/2 Right front door speaker group 30L
H4/2h1 Speaker 1 29L
H4/2h2 Speaker 2 30L
H4/2x1 Right front door speaker group connector 29J
H4/3 Left rear door speaker 34L
H4/4 Right rear door speaker 36L
H4/5 Left front door speaker 32L
H4/6 Right front door speaker 33L
H4/7 Left rear speaker 38L
H4/7h1 Speaker 1 37L
H4/7h2 Speaker 2 39L
H4/7x1 Left rear speaker connector 37J
38J
H4/8 Right rear speaker 40L
H4/8h1 Speaker 1 40L
H4/8h2 Speaker 2 41L
H4/8x1 Right rear speaker connector 39J
41J
H4/11 Center fill tweeter speaker (mirror base) 26L
M11
Automatic antenna (radio/telephone)
14L
N10 Combination relay (turn/hazard signal,
heated rear window, wiper motor)
9L
N40/3 Sound system amplifier 23A
28A
36A
U58 Valid for sedan and limousine 34F
U86 Valid for replacement mast 16F
U611 Valid for Coupe 31F
W6 Ground (left wheelhousing in trunk) 14H
26E
W12 Ground (center console) 2E
14E
X4/17 Terminal block (circuit 15C) 9H
X35/1 Left front door separation point 27H
31H
X35/2 Right front door separation point 29H
32H
X35/3 Left rear door separation point 34H
X35/4 Right rear door separation point 35H
X39/3 Left and right front speakers separation point (4-pole) 9E
X39/4 Left and right front speaker system intermediate connector (4-pole) 27E
X39/12 Radio mute/transmitter-receiver connector (2-pole) 5E
X46/5 Terminal block (right foot well) 12H
Z7/28 Circuit 30 connector sleeve Radio/ sound system (from fuse F4f16) 1G
13G
Z28/1 Left rear speaker group connector sleeve (+ signal) 38G
Z28/2 Left rear speaker group connector sleeve (- signal) 37G
Z28/3 Right rear speaker group connector sleeve (+ signal) 39G
Z28/4 Right rear speaker group connector sleeve (- signal) 41G
Z28/18 Sound system/antenna control connector sleeve 2G
14G
19G
25G
Z81 Circuit 58d connector sleeve 3E
*U104 00.19-2010
Speed signal
0
*U118 00.19-2721
Voltage distribution, circuit 15c
0
*U34 82.20-2000
Interior lighting
0
(SONORIZAÇÃO): Diagrama do Sistema BOSE de Som (W140) W140som1
(SONORIZAÇÃO): Diagrama do Sistema BOSE de Som (W140) W140som2
(SONORIZAÇÃO): Diagrama do Sistema BOSE de Som (W140) G9b
Masculino Mensagens : 3813
(SONORIZAÇÃO): Diagrama do Sistema BOSE de Som (W140) Empty Re: (SONORIZAÇÃO): Diagrama do Sistema BOSE de Som (W140)
Mensagem por AEP Qua 26 Set 2012, 23:33
Show Fass! Extremamente util!
Mensagem por Alexandre - PR Qui 27 Set 2012, 01:58
Legal!
Parabéns Fass.
Vai ser muito útil para os atuais e futuros proprietários das W140.
Masculino Mensagens : 3167
