Brabus C58
Brabus C58
1998 BRABUS C 5.8
Read more: http://mbworld.org/forums/c36-amg-c43-amg-w202/317786-1998-brabus-c-5-8-a.html#ixzz2Llzod8C6
The heart of the 1998 BRABUS C 5.8 is a 5.8 liter version of the eight-cylinder three-valve powerplant of the S 500, which has found a new home in the tight confines of the small engine bay of the Mercedes-Benz W202 C-Class C 43 AMG. The engine itself is built by BRABUS in Germany for export only. As the engine was built for export outside of Germany, and as the BRABUS C 5.8 was never a BRABUS “production” vehicle, BRABUS U.S.A. stated this is the only one of its kind with the United States. To increase its displacement BRABUS uses a custom block, a crankshaft with longer stroke and larger pistons. In addition, the cylinders are fine-machined and fitted with custom camshafts. Reprogrammed engine electronics also contribute to the power output, and finally the top speed governor is deleted. BRABUS states the top speed to be 180 mph +/-. Specifications: Body: Mercedes-Benz C-Class W 202; Basis: C43 AMG Engine: BRABUS 5.8L; Basis: Mercedes M 113 V8 Displacement: 5727 cm³ Bore x Stroke: 99 x 93 mm Power Output: 400 hp / 294 kW at 5,750 rpm Max. Torque: 427 foot pounds / 579 Nm at 3,000 - 4,250 rpm Compression: 10.4 : 1 Powertrain: Five-speed automatic transmission, rear-wheel drive Brakes: BRABUS high-performance brake system Version 1: Including 2 six-piston-aluminum-fixed calipers front; 2 vented perforated front discs; steelflex brake hoses; brake pads; etc. Wheels: BRABUS Monoblock IV: Three Piece 18” wheels; color matched to the vehicle Interior: BRABUS floor mats velour: Black with BRABUS Logo; 3-piece BRABUS Aluminum Pedal Kit. Exterior: Chrome plated BRABUS C58 logos for boot lid Replace MB-star with BRABUS logo on bonnet Set of BRABUS logos for side of the car |
iveiga- Usuário Ouro
Re: Brabus C58
Belo post.
jrcl23- Usuário Platina
Re: Brabus C58
Olha aí os bancos bicolores....
pedroftalmo- Usuário Ouro
Re: Brabus C58
Belo conjunto, e pelo visto uma raridade!
Existem dados de quantas dessa foram fabricadas?
Re: Brabus C58
Muito bacana o carro! Mas acho que o confrade Iveiga poderia traduzir esse texto, dá um pouco mais de trabalho mas afinal aqui nos comunicamos em Portugues! Abraço.
» (BRABUS): Com queda do euro, Brabus reduz preços de seus carros no Brasil
» Brabus: a fábrica
» Kit Brabus
» Brabus dá 850 cv ao Mercedes E63 AMG
» (X204): GLK BRABUS V12
» Brabus: a fábrica
» Kit Brabus
