Duvida sobre a bomba de combustivel da W124 - E420
AMBAPTISTA
Marcelo
Amigos,
Preciso de uma opinião dos mais experientes. Gostaria de confirmar se a bomba abaixo é mesmo a ORIGINAL da E420 w124.
![Duvida sobre a bomba de combustivel da W124 - E420 Bomba-gasolina-bosch-original-mercedes-jaguar-xj-0580254911_MLB-F-192085774_1448](https://2img.net/h/bimg1.mlstatic.com/bomba-gasolina-bosch-original-mercedes-jaguar-xj-0580254911_MLB-F-192085774_1448.jpg)
![Duvida sobre a bomba de combustivel da W124 - E420 Bomba-gasolina-bosch-original-mercedes-jaguar-xj-0580254911_MLB-F-192085774_7600](https://2img.net/h/bimg1.mlstatic.com/bomba-gasolina-bosch-original-mercedes-jaguar-xj-0580254911_MLB-F-192085774_7600.jpg)
![Duvida sobre a bomba de combustivel da W124 - E420 Bomba-gasolina-bosch-original-mercedes-jaguar-xj-0580254911_MLB-F-192085774_2431](https://2img.net/h/bimg2.mlstatic.com/bomba-gasolina-bosch-original-mercedes-jaguar-xj-0580254911_MLB-F-192085774_2431.jpg)
![Duvida sobre a bomba de combustivel da W124 - E420 Bomba-gasolina-bosch-original-mercedes-jaguar-xj-0580254911_MLB-F-192085774_2157](https://2img.net/h/bimg1.mlstatic.com/bomba-gasolina-bosch-original-mercedes-jaguar-xj-0580254911_MLB-F-192085774_2157.jpg)
Marcelo- Usuário Prata
Re: Duvida sobre a bomba de combustivel da W124 - E420
Achei isso aqui, Marcelo:
[size=9][size=9][size=12]
[size=9][size=9][size=12][size=21]
BOSCH ELECTRIC FUEL PUMP 0580254911
[size=9]GENUINE BOSCH FUEL PUMP
[size=9]Applications:
Mercedes
190 W201 M103.942 86-94 4cyl 2.6L
260 W124 M103.940 89-92 6cyl 2.6L
300 W124 M103.983 86-92 6cyl 3.0L
300 W124 M103.940 90-92 6cyl 2.6L
300 W124 M104.942 92-93 6cyl 2.8L
300 W124 M104.980 89-92 6cyl 3.0L
300 W140 M104.990 91-93 6cyl 3.2L
320 W124 M104.992 92-93 6cyl 3.2L
400 W140 M119.971 91-93 8cyl 4.2L
420 W126 M116.965 85-92 8cyl 4.2L
560 W107 M117.967 85-91 8cyl 5.6L
560 W126 M117.968 85-91 8cyl 5.6L
C280 W202 M104.941 93-97 6cyl 2.8L
E280 W124 M104.942 93-96 6cyl 2.8L
E320 W124 M104.992 93-95 6cyl 3.2L
S280 W140 M104.944 93-98 6cyl 2.8L
S320 W140 M104.990 93-98 6cyl 3.2L
S420 W140 M119.971 93-95 8cyl 4.2L
S500 W140 M119.970 93-95 8cyl 5.0L
S600 W140 M120.980 93-96 12cyl 6.0L
SL280 W129 M104.943 93-98 6cyl 2.8L
SL600 W129 M120.981 93-95 12cyl 6.0L
SLK200 W170 M111.946 96-00 4cyl 2.0
[/size][/size][/size][/size][/size]Mercedes
[size=9]Espero que ajude. Abraço. André.
AMBAPTISTA- Usuário Bronze
Data de inscrição : 31/10/2012
Não vi a associação exata W124 e M119, que deve ser o motor do seu carro...será que serve? Tenho dúvidas...mas não sou experiente no assunto.
A bomba visualmente é essa mesmo, porem ja comprei no ebay para a E 420 e veio uns 2mm maior na circunferencia. A da 190 é a mesma e a E420 usa 2 bombas.
Abraço.
Abraço.
Marcelo Loureiro- Banido
Marcelo para ter certeza se essa bomba é a que equipa o seu carro, precisaria verificar a bomba que esta instalada.
Dando uma busca no ebay.com aparecem dois tipos de bomba para a W124 E420, podendo ser bosch como essa ou pierburg. Inclusive no mesmo ano de fabricação.
Se forem duas bombas no carro, é essa mesmo.
Estou estranhando o preço praticado no ML. Muito barato, levando a crer que tem algo estranho aí.
Marcelo segue site do ebay constando a bomba do seu carro. Pelo menos é igual a minha que é versão alemã, que parece ser o caso da sua.
Abraço.
Abraço.
É outro part number essa que o Marcelo Loureiro postou...
0580254950
A que você colocou no primeiro post é 0580254911
0580254950
Caro AMBAPTISTA;
No site postado tem uma observação na aplicação dos modelos bosch dizendo o seguinte:
"Mercedes Reference # 002 091 5901, 002 091 8801, 003 091 5301
fits also Bosch Ref#: 0 580 254 911 or 0 580 254 950"
Abraço.
Abraço.
Perfeito, Marcelo!
Então serve qualquer um dos part numbers.
Excelente!
E o preço está bom mesmo, aparentemente.
Excelente!
Epicco,
Descobri que no meu carro tem 2 bombas xing-ling, apesar de estarem funcionando perfeitamente vou colocar as originais.
Visualmente essa é identica a que tinha na minha boa e velha 300E, i muito parecida com as xing-lings.
Marcelo,
Perfeita observação.
Vou comprar essa bomba. vamos ver se não vou receber uma pacote com pedras dentro...hehehehehehehe
VLW
VLW
Marcelo,
No EPC consta o mesmo código original (atualizado) tanto para a minha como para a sua: A 003 091 5301.
Guilhermino- Usuário Ouro
Exatramente William,
Mas veja a foto dessa bomba com esse nro.
É igualzinha a do anuncio.
cuidado com essa bomba do ML.
Essa do ebay esta US$ 150.......
Às vezes acho essas tabelas de equivalência meio confusas. Consultando o EPC e o catálogo Bosch Brasil, encontrei o seguinte:
1) A bomba original era a A 002 091 8801, que foi substituída pela A 003 091 5301;
2) A bomba Bosch 0 580 254 950 equivale às originais A 002 091 8801 e A 003 091 5301;
3) A bomba Bosch 0 580 254 911 é um modelo universal que, além da Mercedes, tem equivalência também na Ford e na Ferrari. Na Mercedes, consta que equivale à A 002 091 8801 e a alguns outros códigos, porém não é mencionado que corresponda à A 003 091 5301;
4) Ambas as bombas Bosch fornecem 4 bar de pressão e vazão de 95 L/h.
Fico meio com o pé atrás de verificar compatibilidade por cadeia de equivalências, mas já fiz isso algumas vezes e deu certo, e entendo que se: 1) a A 002 091 8801 e a A 003 091 5301 correspondem à 0 580 254 950; e 2) a 0 580 254 911 corresponde à A 002 091 8801; então a 0 580 254 911 deveria corresponder à 0 580 254 950, e deveria servir.
Também é o que consta no anúncio do eBay que o Marcelo Loureiro postou.
Aliás, depois de ver o anúncio, verifiquei de novo o EPC e vi outro detalhe: a partir do chassis número C226336, a bomba original passou a ser a A 000 470 5994, e montada uma só.
De fato o preço está muito baixo.
Já precisei trocar das duas 190E e paguei o dobro.
Tenho feito muitas compras no ML, e sempre me apoio na reputação do vendedor.
Este tem uma ótima reputação de negócios concretizados.
Esta peça pode ser de um mercado que ele não atinja muito...
Paulo Cumani- Usuário Iniciante
Peça recebida perfeita na caixa, lacrada, e originalíssima.
» [VENDO] Bomba de combustível Bosch para KE-Jetronic W124, W201, R129, W126, etc
» Dúvida sobre GPS
» Dúvida sobre ESP
» W124 E420 sportline
» (COMPRO): W124 E420
» Dúvida sobre GPS
» Dúvida sobre ESP
